1 - 4 of 4 Posts
My recent disaster with a failed Raptor has made me wonder about what Id do if stuck without help. The obvious solutions are to get towed or car -trailered home. But there might be another way. AC drive owners need not read further. Perhaps one could parallel up the cells to a lower voltage to allow direct connection In my case Ive got 46 cells of LFP & 12 off AGM so it can really be only halved to 72V or if one cells is left out to 48V. Then there is the problem of the enormous current at starting. Id make up a starting resistor out of some old fencing wire aimed at limiting starting current to say 200A, so need around 0.25 Ohms. This needs to be shorted out so need another contactor. Maybe use a starter motor contactor. In my case I have my old Jones SCR Chopper built 40 years ago that might be still useable. Ill get it out. What would other owners do? David sharpe
URL: http://lists.sjsu.edu/mailman/private/ev/attachments/20110124/494311ac/attachment.html
Discussion Starter · #2 ·
Hi Dave,
We (I)'ve been here before on the EVDL. One of the benefits of
keeping the clutch when converting. Just keep a good pair of jump
leads in the vehicle and if you suffer a failed controller, put the
vehicle in neutral, tap the pack at enough cells to give you 1500 RPM
or so and off you go. Might be a bit slow but it'll get you home (or
to help) eventually. Just watch the cell volt levels tho. You'll
have to swap the jump leads to the next lot of cells when the first
run out of juice.
Regards, Martin Winlow
Herts, UK
http://www.evalbum.com/2092
www.winlow.co.uk
> sharpe
Hi David,
Yep, that is exactly how it was done
in the beginning (I mean 100 years ago
give or take ;)
You can search the archives with the term
"contactor controller" to see a long discussion
on this, including some info from drivers of
actual original EVs.
Regards,
Cor van de Water
Email: [email protected] Private: http://www.cvandewater.com
Skype: cor_van_de_water IM: [email protected]
-----Original Message-----
From: [email protected] [mailto:[email protected]] On
Behalf Of David Sharpe
Sent: Monday, January 24, 2011 5:47 PM
Subject: [EVDL] Stranded by a blown controller?
URL:
ttachment.html
I tried the starter motor relay thing and don't recommend it! All six of those
buzzards in parallel would get too hot to touch.
I did have my controller die, and just wired around it. No drama, as I have a
sepex so overrevving was not a danger.
To: Electric Vehicle Discussion List <[email protected]>
Sent: Mon, January 24, 2011 5:17:07 AM
do? David sharpe
URL: http://lists.sjsu.edu/mailman/private/ev/attachments/20110124/04e85eed/attachment.html
1 - 4 of 4 Posts
