The law of reality states 3 properties:
1. You can have it inexpensively (cheap).
2. You can have it quickly.
3. You can have high-quality.
The reality is that you ever get to have only 2 of these at any given time:
1. You can have it fast and cheap, but the quality's going to suck.
2. You can have it cheap and high-quality, provided you are prepared to wait
forever.
3. Finally, you can have it both high-quality and quickly, only if you spend
a LOT.
-Phil
----- Original Message -----
To: "Electric Vehicle Discussion List" <[email protected]u>
Sent: Sunday, October 14, 2007 2:41 AM
Subject: Re: [EVDL] adding range to existing pack
> From: Michael Mohlere
>> If I wanted to add some range to my EV... what is the
>> best/easiest/cheapest way to do same?
> Best, easiest, and cheapest are probably three different solutions. Pick
> one!
> Before looking at the battery pack itself, I'd start by finding out if
> there are any simple little things that are limiting your range. Things
> like soft or high rolling resistance tires, dragging brakes, bad wheel
> alignment, hot connections or wiring, etc. Fixing these could easily add
> 10-20% to your range.
> Next, consider your driving style. Do you accelerate quickly and drive
> fast (drag race to the next stop light)? Are you shifting to run the motor
> at too low an RPM, so the motor and controller are getting hot? Do you
> drive until you are almost up to a stop sign, and then brake heavily?
> These are all bad for range. Changing your driving habits can easily add
> another 10-20% to your range.
> Is your present battery pack in good shape? Are they well balanced (all at
> about the same voltage after a long drive)? Are there any weak ones that
> are limiting your range? If a battery is weak enough, removing it from the
> string will actually *increase* your range.
> Are the batteries cold? Sometimes, all it takes to increase range is to
> add a heater to keep them around 80 deg.F.
> Once you've gotten through all these "cheap / easy" improvements, then
> it's time to consider more expensive and elaborate ways to increase range.
>> I have read a lot about "buddy pairs", but I was thinking more
>> on the lines of creating another 120 volt pack with some smaller
>> batteries...
> The best solution is probably to have a single pack that meets your range
> and performance needs. Buddy packs and twin strings are "work-around"
> measures to avoid special case problems, such as the batteries you need
> weren't available or affordable, or didn't fit.
> If you want to try a hybrid battery pack with two different strings of
> batteries, I think in general you should include some kind of charge
> controller to control/limit how much current comes from each pack. This
> charge controller will also need to manage charging, so each pack is
> charged correctly.
> Just like motor controllers, this charge controller could be as simple as
> a set of contactors, or as complex as a full-blown motor controller.
> Luckily, it doesn't have to handle nearly as much power as the motor
> controller, and so can be smaller. It is only being asked to move power
> across a fairly small and limited voltage range, and can be sized for the
> average power rather than the peak power.
> As a simple example, suppose your present system has ten 12v batteries; a
> 120v pack, controller, and motor. You could add an 11th 12v battery,
> 12v-to-120vac inverter, and simple battery charger. Let's say this new 12v
> battery is rated at 30 amphours at the 1-hour rate. Then you need a 360
> watt inverter. Setup your charger to draw 12v at 30a, to produce 120v at
> about 2.5a (due to inverter and efficiency). You've added not quite 11/10
> = 10% to your range.
> The principle can be expanded to larger 2nd packs.
> "Excellence does not require perfection." -- Henry James
> Lee A. Hart, 814 8th Ave N, Sartell MN 56377, leeahart-at-earthlink.net
forever.
a LOT.
-Phil
> one!
>> batteries...
> charged correctly.
