1 - 3 of 3 Posts
Unfortunately, the freeway onramp leads to a very steep climb for maybe 1/2
mile. You hit the freeway going about 50 mph, and have to accelerate to 65
mph on that climb. In 3rd gear, my EV just doesn't have the torque to do
it. In fact, it loses speed. I've got an ADC 8-inch motor, which has a
redline of 8,000 rpm. According to my calculations, the motor would be
doing 7,600 rpm at 60 mph in 2nd gear. Would it be save to accelerate up to
60 in 2nd gear for that short stretch? That way, at least, I wouldn't be
typing up traffic.
Thanks.
Bill
Discussion Starter · #2 ·
Hi Bill,
> to
Your motor will have *very* little power at that rpm.
at what rpm does your controller come out of motor side current limit?
is there a range in which you are in battery current limit?
either of those events determines your max power (torque at the wheel).
use your gearbox to keep the motor at max power, and you will get the best
possible acceleration.
if you try to spin the motor past the point where your controller comes out
of current limit and goes full on, torque falls off exponentially.
for most DC motor, controller, battery setups, this occurs between 2000 and
3000rpm.
Matt
----- Original Message -----
To: "'Electric Vehicle Discussion List'" <[email protected]>
Sent: Monday, November 22, 2010 5:45 AM
Subject: [EVDL] The Torque is the Torque, of course, or course
> 1/2
> 65
> to
> typing up traffic.
> Thanks.
> Bill
No virus found in this incoming message.
Checked by AVG - www.avg.com
Version: 9.0.869 / Virus Database: 271.1.1/3269 - Release Date: 11/21/10
03:34:00
On 21 Nov 2010 at 14:45, Bill Dennis wrote:
> In 3rd gear, my EV just doesn't have the torque to do it.
I know it sounds odd, but try 4th, not 2nd. Especially with a DC series
motor, torque is much higher at low RPM. When you need more acceleration,
you actually have to >upshift<.
Just watch out for motor heating and battery stress from the high currents
that result.
EVDL Administrator
Note: mail sent to "evpost" and "etpost" addresses will not
1 - 3 of 3 Posts
