[EVDL] Thundersky Lithium Batteries
1788 Views 5 Replies 1 Participant Last post by  EVDL List
Looks like Thundersky is making a 12V model of their Lithium Batteries.
Anyone using these or know the price ?
http://www.thunder-sky.com/products_en.asp?fid=66&fid2=82
Thanks;
Dennis
Elsberry, MO
http://www.evalbum.com/1366
URL: http://lists.sjsu.edu/mailman/private/ev/attachments/20110215/4cfee5ae/attachment.html
1 - 6 of 6 Posts
hmmmm...
"WARNING: This cell is not suitable to be used as a traction battery.
It is designed to replace lead acid starter batteries in ICE
vehicles."
http://kostov-motors.com/tractionmotors/kostovevmotors-and-kits/lithiumbatteriesbmsandchargers/lp12v90ah/
On Tue, Feb 15, 2011 at 8:24 AM, Pestka, Dennis J
> Thanks;
> Dennis
> Elsberry, MO
There are so many errors in their datasheet,
who says that this is correct? There may be
a reason, but I do not expect that they have
found a Li-ion cell that does not like cycling
and thus this must be avoided.
I'd more expect that their continuous current
spec of 3C will not allow but the lighter EVs
or those with high voltage packs.
We also know that long strings (high voltage
packs) are notoriously difficult to keep in
balance and avoid over charge or over discharge...
The datasheet seems to indicate that the charge
voltage goes above 17V which would indicate they
are still at their game of charging to 4.2V per
cell (or even above!)
While the discharge stops at 2.5V per cell, *if*
they are balanced.
Serious errors in their datasheet are that the
90Ah cell gets charged and discharged with 90A
for *two* hours. That would make it a 180Ah cell.
The Cold cranking discharge at 600-ish Amps at
various temps suggest that the battery is
completely discharged (2.5V per cell) after
6 seconds, which would make it an approx 1Ah battery,
so I expect that the scale is actually in minutes,
even thought the specs say not to discharge 10C
for more than 10 sec.
Really weird is that their charge curve starts
with 1 volt per cell (4V on the battery) and very
reduced charge current. I do not know what they
intend to say with that.
Cor van de Water
Email: [email protected] Private: http://www.cvandewater.com
Skype: cor_van_de_water IM: [email protected]
-----Original Message-----
Sent: Thu 2/17/2011 12:12 AM
Subject: Re: [EVDL] Thundersky Lithium Batteries
hmmmm...
vehicles."
> Thanks;
> Dennis
> Elsberry, MO
A non-text attachment was scrubbed...
Name: not available
Type: application/ms-tnef
Desc: not available
Url : http://lists.sjsu.edu/mailman/private/ev/attachments/20110217/39979e9b/attachment.bin
Wow isn't that nice a built in BMS .. Or is that just a great piece of humor
? Bill I love your Humor,er "BS" [:^)}
* ** Regards,
Dennis Lee Miles .COM
[email protected] <[email protected]>
Phone: 1 (863) 944 - 9913
Tampa, Florida* *33613*
Bill Dube <[email protected]> wrote:
> Don't use them in series.
> There is certainly a big internal transistor that disconnects the
> battery from the load/charger when the battery is full or empty. This
> will not allow the other batteries in the series to fully charge.
> This big transistor probably has a voltage rating of 20 to 30 volts,
> maximum. If you put several of these batteries in series, then you
> will exceed the voltage rating of that big transistor. When one of
> them opens up under load or under charge, the transistor will be
> ruined. It could catch fire. It will certainly never function again.
> Bill D.
> >they are balanced.
> >Cor van de Water
> >From: [email protected] on behalf of J Bills
> >hmmmm...
> >vehicles."
> > > Thanks;
> > > Dennis
> > > Elsberry, MO
> > > URL:
> >Name: not available
> >Desc: not available
> >Url :
URL: http://lists.sjsu.edu/mailman/private/ev/attachments/20110217/b072fb67/attachment.html
So, the question is: does Bill have data or is he guessing?
Cor van de Water
Sent: Fri 2/18/2011 1:08 AM
* ** Regards,
> Bill D.
> >they are balanced.
> >Cor van de Water
> >hmmmm...
> >vehicles."
> > > Thanks;
> > > Dennis
> > > Elsberry, MO
> > > URL:
> >Name: not available
> >Desc: not available
> >Url :
Name: not available
Desc: not available
Url : http://lists.sjsu.edu/mailman/private/ev/attachments/20110218/068c8f01/attachment.bin
>> This will not allow the other batteries in the series to fully
>> charge.
Dennis Miles wrote:
> Wow isn't that nice a built in BMS... Or is that just a great piece
> of humor? Bill I love your Humor, er "BS" [:^)}
I have no idea what Thundersky is using in their lithium replacement for
a 12v starting battery. But, I designed the BMS for a client for just
such an application.
The 12v electrical system in a car can easily exceed the maximum safe
voltage for the lithiums. People also routinely connect their own 12v
chargers, which go even higher. They also forget and leave things on, or
keep cranking an engine that won't start until the battery is way below
the minimum safe voltage for the lithiums.
Since the battery can *start a fire* if abused like this, I felt that
you *must* include a BMS that can disconnect the battery from the system
if an overvoltage or undervoltage occurs. Like Bill said, this means a
big transistor or contactor in series.
I chose to use transistors. I had six MOSFETs, three in parallel, and
these two groups in anti-series to act as a switch that can stop current
flow in either direction. These transistors can handle starting currents
(hundreds of amps). But due to space and lack of cooling, they can only
do it for seconds.
Also, these transistor have to be low voltage (30v) to get the extremely
low on-resistance needed.
Such a battery can't be connected in series for EV use. The transistors
would overheat from sustained high current, and if they had to turn off,
they would be breaking the *total* voltage of the pack, not just that
one battery's worth.
1 - 6 of 6 Posts
