1 - 6 of 6 Posts
Discussion Starter · #2 ·
Chris,
The price of Lithium has been $1.15 per Ah for some time now,
It may be possible to get better deals but for a 80 Ah pack
(to stay below 3C discharge, not for capacity needs)
you would need approx 90 cells in series, so
80 x 90 x $1.15 = $8.3k for just the cells.
Regards,
Cor van de Water
Email: [email protected] Private: http://www.cvandewater.com
Skype: cor_van_de_water IM: [email protected]
-----Original Message-----
From: [email protected] [mailto:[email protected]] On
Behalf Of Christopher Zach
Sent: Tuesday, November 02, 2010 4:48 AM
To: [email protected]
Subject: [EVDL] UB's are not working,where are the best places to get
Hawkers?
Ok, after 2 years of trying, being gentle, firm, and weeding the pack
for failed batteries I have come to the conclusion that these UB12-260's
are worthless in driving a pack.
They just don't work. The final straw was a 3 mile drive with the pack
down 6ah when the pack (50 UB12-260's arranged for two strings of 25)
literally dropped most batteries below 10 volts at a 50a draw rate.
*most* of the batteries were dropping, a few were at 10.5 or so. So it's
not single batteries, the whole pack is basically hopeless. It will
happily charge up to 14.4 volts per battery, but that is el-it. 6ah
capacity for a 52ah pack.
What a pain. I can use the car through the winter for <5 mile trips, but
anything more is a joke. I would get better range with D batteries at
this point.
The right answer is and always was Hawker 26ah batteries. Even the used
ones that one could buy for $50 would give me 3 years of >30 mile range
life. And at the end of that and 3 years of sitting in my driveway, 30
out of the 50 are still in fine shape and able to handle a 100a
discharge test to 11 volts *without being charged in 3 years!*
Right now I would be better off putting those into my car and running
one string. But it's cold now so I will have to wait till spring. I feel
like a dolt; I replaced them because the range was *only* 20 miles. I
have never gotten 15 out of this pack, even when new.
The question though is where to get them? These used to be a few people
selling them out of UPS units, are they used anywhere anymore? Failing
that, what's the best way to get QTY 25 and 50? At $150 a battery I'm
looking at a 7500 pack. At $50 a used battery I was looking at $2500
which isn't bad for 3 years.
But this pack ($50 per battery for a total of $2500) has been a complete
waste of time and money.
Or has the price of lithium gotten any better?
C
I would strongly consider it if I were you!
For $7500 you could afford a 90 cell (300V) pack of 70AH - roughly
twice the usable capacity of the lead, and should last longer too.
I'm not sure if 70AH cells are an available size so you may have to go
up or down a bit.
And in general you should stick to 1C for the continuous current
requirement. So if you chose 60AH cells, that would give you about
18kW or 50kW peak - quite respectable for a small light car, but no
good for drag racing.
I replaced 100AH Saft Nicads in my Peugeot 106 with 180AH Lithium
about a year ago (and 11,000 miles) and haven't regretted it so far.
Remember to allow for a BMS that works!
Chris Zach <[email protected]> wrote:
> There's something I do know; the Prizm typically pulls between 60a when
> cruising at 60mph with a voltage of about 310v. Driving the way I do the
> current goes up to about 120 or so for 5 seconds at a shot and 200a when I
> am really wanting to get somewhere.
> Peak continuious draw for me would be 140a for 3-4 minutes when climbing out
> of Frederick MD on the way to Hagerstown.
OK, so even the quite small 60-70AH cells should be happy. Does
anyone use cells of that size and can verify this?
> I've heard Lithium batteries were bad. But that was 3-4 years ago; are they
> better now?
Very much so. The LiFePo4 batteries have a good history (albeit a
short one). I think it was the older LiMn chemistry, and a shipment
of poor quality ones from TS which caused a lot of people problems
before.
> And how much usable capacity is in each battery? Does 60ah mean
> you can draw out 60ah at 60a draw with a voltage of 3.0 volts as your
> E-meter passed 60a? Or is it really 40,30,20,5?
Yes, pretty much 60AH. Even more than the rated capacity sometimes!
Although, as with any battery, running them down below 20% frequently
will wear them out sooner.
Evan;
What BMS are you using
Thanks;
Dennis
Elsberry, MO
http://www.evalbum.com/1366
Sent: Tuesday, November 02, 2010 4:31 AM
Subject: Re: [EVDL] UB's are not working,where are the best places to
get Hawkers?
On Mon, Nov 1, 2010 at 11:18 PM, Christopher Zach <[email protected]>
> people selling them out of UPS units, are they used anywhere anymore?
> Failing that, what's the best way to get QTY 25 and 50? At $150 a
> battery I'm looking at a 7500 pack. At $50 a used battery I was
> looking at $2500 which isn't bad for 3 years.
> complete waste of time and money.
For $7500 you could afford a 90 cell (300V) pack of 70AH - roughly twice
up or down a bit.
requirement. So if you chose 60AH cells, that would give you about 18kW
or 50kW peak - quite respectable for a small light car, but no good for
drag racing.
I replaced 100AH Saft Nicads in my Peugeot 106 with 180AH Lithium about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1 - 6 of 6 Posts
