m gol <
[email protected]> wrote:
>> Trying to deal with the critics that I'm still using fossil
>> fuel for my ride.
>> Are there any inexpensive grid-tie inverters to
>> connect some solar panels directly to my grid?
>> I was thinking just use a couple panels, less than 500 watts.
> No. Must use an approved inverter at about $2000, and need at
> least 10 large hi wattage panels $500 ea. They get you coming
> or going, but you can make a solar charger for your own EV.
> One Harbor Freight panel per battery at about $100 or less ea.
It's not *quite* that bad. It's easy to get something that works. It's just that the US utilities have written regulations to make it has hard as possible to meet. For some reason, I get the impression they don't want us to be able to generate our own power!
I have five old PV panels, Arco M52L, that cost me about $50 each. They run a Trace Microsine grid intertie inverter, which generates 120vac at up to 200 watts -- it cost about $300. This is a small simple cheap system to generate AC power and push it back into the grid safely.
"Excellence does not require perfection." -- Henry James
Lee A. Hart, 814 8th Ave N, Sartell MN 56377, leeahart-at-earthlink.net
