These were two different strings but I think some mixed them together. But as
usual the group just says that it doesn't work out of hand. Probably true but
does anyone know for sure? The discussion then disintegrates to the best known
method. Does anyone know the answer to the original questions. Does either of
these methods work? You would think the Vancouver EAA or a group in Northern
Washington would know these people or even might be employees. Did you buy the
service? Did you buy the charger? Did a friend use them? The true and final
answer is what I want. Proof one way or another. I bet the same stuff was
talked about when Soniel chargers came out and now they are well respected. So
please no speculation. Just the facts Mam. If someone got burned please speak
up. If it worked for you how did it work, what results & now what is your
opinion based on first hand experience. Thanks a bunch. Lawrence
Rhodes........
Rhodes........
