Hi All,
Is the voltage vs speed relationship basically a straight line? I am
currently running a 48 volt nominal pack and have a top speed of 32 MPH.
The controller is not in current limit at only 120 amps with a constant
current rating of 325 amps. If I up the pack voltage to 72 volts, could I
expect the top speed to increase to approximately 48 MPH? This is assuming
I don't change the ratios and the higher voltage controller doesn't end up
in current limit. The expected controller is a Curtis 1209B with a 1 hour
rating of 175 amps.
I am contemplating going from the current pack of 8 T145s which is 48V 265
AH to possibly a pack of 6 Genesis XE60 which would be 72V and 62 AH. I
realise this would cut my range down to 25-30% of what I have now. I would
look at the XE90s but I am told the lead time is 22 weeks.
respectfully,
John
The Skunk
http://www.austinev.org/evalbum/751
rating of 175 amps.
respectfully,
John
The Skunk
