Son of a.....
Here at work, I just had an epiphany, and not the good kind!
To correctly measure battery amps, the ammeter shunt should be placed at th=
e end of the string, between the last battery and the controller right?
Well the cable that arced on me on the way to last Saturday's "Show 'n Shin=
e" IS the last cable and the shunt is NOT ON IT. Ok, wait a sec....does it =
matter if the shunt is on the positive end or the negative end? I'll double=
-check when I get back to the car. Maybe it's on the positive end of the st=
ring.
OMG I'm going to cry if the shunt is in the middle of the pack somewhere. I=
found it in place and just assumed it was correct. I may have been hammeri=
ng my batteries way worse than what the meter shows if this is true!
Boo!Scare away worms, viruses and so much more! Try Windows Live OneCare!
http://onecare.live.com/standard/en-us/purchase/trial.aspx?s_cid=3Dwl_hotma=
ilnews
ring.
ilnews
