Hello Tehben,
The ampere is going to be the same anywhere in the circuit when you cannot
these batteries up all in series.
Using fuses or circuit breakers, the ampere should at least be 125 percent
over the maximum amount you may use. The voltage of the fuse is at the
rated voltage that is use. If you have a 250 volt circuit, than a 250 volt
rating fuse will work.
Make sure you use DC fuses on a DC circuit. It does not matter if you use a
higher voltage fuse, unless the fuse size in the higher voltage may get too
large for installation.
In my EV, I use a 500 v Limitron rated fuses that is the size as a 12 volt
fuse. The fuse holders are all 600 v rated that accepts the same size fuse
down to 0.1 amp.
At one time, I had a battery box in the front and in the back. I used the
400 amp Anderson Connectors to connected these battery boxes in series and
have only one 400 amp semi-conductor fuse in the circuit.
Roland
----- Original Message -----
To: "EV mail list" <[email protected]>
Sent: Friday, August 17, 2007 10:58 PM
Subject: [EVDL] wiring and fusing battery box?
> If I have 3 battery boxes, #1 48v(4 cells), #2 120v (10 cells) and #3
> 144v (12 cells)
> Should I wire them so each box is a big battery and string them up
> with a return cable? Or should I have each box split with the to and
> from, so that there isn't a long return cable?
> If I fuse each box can I use all fuses rated for 312v (should I use
> 400v fuse?) or do the fuses have to be different sizes depending on
> where they are in the string?
> would it be a good idea to have breakers instead so I can break up the
> pack while performing maintenance?
> With less than 300amp current draw what size cable should I use? Is
> gauge 4 the same as AWG 4?
> Thanks,
> Tehben
> '90 Toyota 4x4 Pickup
> 'hElix EV'
> Website: www.helixev.com
> evalbum: http://www.austinev.org/evalbum/1225
down to 0.1 amp.
Roland
> 144v (12 cells)
> Thanks,
> Tehben
> 'hElix EV'
