1 - 1 of 1 Posts
There is something about zener regs that I don't understand.
Looking at Lee Hart's design, I see that the higher-voltage zener is
specified at 6.8v.
If I were to put these regs on my pack, how would I ever get a full charge?
USBattery says that I should charge up to a maximum of 7.75v x 26 = 201.5v.
If I use zeners to dissipate excess energy, the pack would never get past
6.8 x 26 = 176.8v, which is obviously WAY below what the manufacturer
considers to be a full charge.
Is that correct? Do I have that right?
If I were to select 7.5v zeners, would that affect the other part
specifications? Would I need differently-sized resistors, or different
bulbs, for example?
Bottom line: I NEED to use zener regs because some of my batts are WAY out
of balance, but I also want to get a good full charge to take advantage of
my new Elcon PFC4000. How do I do both?
Your comments are welcome.
Cheers,
Steve Kobb
http://www.myelectrictruck.com
View this message in context: http://electric-vehicle-discussion-list.413529.n4.nabble.com/Zener-regs-Can-I-get-use-em-still-get-a-full-charge-tp3022882p3022882.html
1 - 1 of 1 Posts
