Roland Wiench wrote:
> Not likely it overcool. I ran the Zilla at -33 below and that's
> even with a
> large radiator fan, large holding tank and a 1 gallon per minute
> pump, and
> also a filter air 150 CFM Dayton blower.
> One LED is a low voltage indicator, and will flash when the main
> battery
> pack goes below the preset advance warning limit you program in
> that should
> be about 5 volts above the low warning limit, where it should stay on
> steady.
> The other LED is a pre-charge status that lights up when you start
> turning
> on the contactor circuit and then both lights should go off after
> start up.
> Also check the trouble codes and clear them out to see what
> happens. It also
> could be a loose or high resistance battery wire or may be a contactor
> bounce that could show a intermitted higher resistance.
> Roland
> ----- Original Message -----
> From: "Mark Dutko" <
[email protected]>
> To: "Electric Vehicle Discussion List" <
[email protected]>
> Sent: Sunday, August 19, 2007 8:17 PM
> Subject: Re: [EVDL] Zilla Engine Light Blinking
>> I bled all viable bubbles out of the system, the radiator does get
>> war and the brass fitting on the pump is quite warm so I assume the
>> coolant is flowing..
>> On Aug 19, 2007, at 6:57 PM, Marty Hewes wrote:
>>> Overcooled? What's it going to do at -20F in Chicago in January?
>>> Is there
>>> something I need to know? I have to wonder if it's a coolant flow
>>> problem
>>> or a temp sensor that's got a mind of it's own?
[email protected]>
[email protected]>
>>> Sent: Sunday, August 19, 2007 8:44 PM
>>>> That's what I was thinking- It should be over cooled I would
>>>> think???
>>>> Mark
>>>> On Aug 19, 2007, at 5:50 PM, David Brandt wrote:
>>>>> That's the reply I got - of course it's over 100 here, and it
>>>>> typically flashes towards the end of the hot afternoon drive, so I
>>>>> can believe it's getting hot. It's hard to believe yours is...
>>>>> David Brandt
>>>>> From: Mark Dutko <
[email protected]>
>>>>> To:
[email protected]
>>>>> Sent: Sunday, August 19, 2007 8:26:56 PM
>>>>> Subject: [EVDL] Zilla Engine Light Blinking
>>>>> I drove my Yaris on the Freeway today and never pulled more
>>>>> than 60
>>>>> battery amps, the engine light would blink every once and a while
>>>>> after the first 5 miles or so. I have the Ev source cooling kit
>>>>> and a
>>>>> fan blowing on the radiator. Is this a temp warning? It's less
>>>>> than
>>>>> 70 outside and I thought I had the controller over cooled. It has
>>>>> also blinked in the evening when it is under 60 outside and using
>>>>> the
>>>>> controller harder.
>>>>> Thanks,
>>>>> Mark
>>>>> _______________________________________________
>>>>> For subscription options, see
>>>>> http://lists.sjsu.edu/mailman/listinfo/ev
>>>>> __________________________________________________________________
>>>>> __
>>>>> __
>>>>> ______________
>>>>> Yahoo! oneSearch: Finally, mobile search
>>>>> that gives answers, not web links.
>>>>> http://mobile.yahoo.com/mobileweb/onesearch?refer=1ONXIC
