hello, may I ask how did you solved the problem with damaged battery module BMS on your Transit Connect EV. I have the same problem, and don't know from which point try to start? (-----ESS Pack 2 Info Codes-----
P0AFC-49 Hybrid Battery Pack Sensor Module
P0B3F-F1 Hybrid Battery Voltage Sense A Circuit Intermittent / Erratic)
-----VCU DTC-----
P1A28 Battery Control Module "B" Critical Fault (same as P1A20)
P1A8B HV Discharger Status Circuit High)
-----VCU DTC-----
