Some keep the clutch, some just shift at the proper RPM like you can do on a regular manual car.I am obviously a novice at this ev converison but am determined to have one up and running by next spring.. I am studying everything i can get my hands on as well as scouring the internet. I just have one simple and i mean simple question about a direct drive without using a clutch/flywheel etc.. What exactly are you keeping on the transmittion and how does it shift without the clutch etc...? please help.. thanks!
As for keeping the transmission, it's about ratios. If your motor RPM is, say, 2,000 and you're going direct drive, you're turning your driveshaft at 2,000 RPM - which may not be desirable given the torque or speed you're attempting to attain.
Keeping the transmission allows you to keep a reduction ratio.
