I'm no expert, but I also drive a Wheego and here's what I think I know.
The Delta Q on my Wheego can be reprogrammed with different algorithms, so I'm guessing yours probably can be too. However, on the 96 volt model, the range of voltage may not go down that low, so it may require a different charger. 72 volt Delta Qs do appear on eBay from time to time. You may search old posts for "Frodus + Delta" for more programming info.
IDk what your cost for the 6 V batteries are, but my preferred path to more range as economically as practical would be using EVTVs blue calb 100s. At $95 each and a huge weight savings I'd expect about the double the 18 miles my Wheego w/lead currently provides. Switching to LiFePo4 would work best with the charger reprogrammed.
My 2 cents..
My 2 cents..
