Hi everyone, tons of great information on this page.
I'm wanting to build a single seat mini buggy along the lines of a Honda Odyssey but electric. I will likely modify some kit plans for a buggy design that normally weighs in at around 618 lbs using a 650cc quad motor that weighs in around 120lbs and makes about 32hp.
I am thinking of using either an AC20 or AC23 from hpevs and running 22 or 24 CALB72 packs in series to power in the neighborhood of 72v/550 amps which should put my power curve right about where I want it.(wheelspin!) With a 60 pound motor and 88lbs of batteries it would make it pretty close in weight to the ICE motor and a gas tank, so it should be quick!
can the CALB batteries handle the top end current? they're rated for 580 max for 10 seconds, can they cruise around 550 for awhile longer?
can these cells handle a ton of vibration? I'd like to be able to flog the heck out of it around a little motocross style track safely.
am I realistic in thinking that I can get about 25 minutes of ridiculous fun run time out of a charge?
with a relatively short run time and a light-ish load to move around is liquid cooling necessary or am I ok staying with air cooled motor and controller?
Am I better off with the AC 23 with a ton of torque and use a higher gear for top end or with the ac 20 and being able to wind out into higher rpm?
Thanks so much!
-Jon
Thanks so much!
-Jon
