Hi it Ragnar again.
I got few questions..
ok, so the zombie has no gearbox just a drive shaft and what you cal it the drive shaft goes into it (LSD) locked diff or something...
okay lets say i have a motor that is 200hp and what spins 8000rpm?,has lsd like zombie (3:50) and 17" tires.. how can i calculat the top speed?
how many rpm´s does a high power motor spin?
what does a high power motor cost?
lets say I have a 100Kw motor do I need for example if i use thundersky 3.2v 90ah than i need what 348 batteries to power it (volt * amper = power??) if 3,2V and 90Ah is 288W i need 348 betteris (348 * 288 = 100224W = 100,0kw?? right
and other question is how power full is the blue mean the zombies brother? and how much will it cost to build a car that has the same power? (using all the same things?) (just talking about the cost of the batteries, motor and controllers.. not how many work hours is put into it and how much the car you use cost)
hope to get some good answers.. thanks.
best regents Ragnar...
