There are many blogs and build threads here that will help you on this. First step, though, is to set your goals for performance and your budget. See if its realistic. Make adjustments as neccessary before you buy ANYTHING. It's ok to ask if the numbers add up. Start with a good plan so that you dont waste a lot of time and money going down the wrong path.
I have some pictures and info on my site, www.jeffeblack.com. I'd be happy to help, as would other people.
Sent from my SM-N960U using Tapatalk
