About half of the Fiorinos have manual gear. The problem is worst for automatic gear since I have to stop the car completely.I've had this issue once. Do you have manual geared car or are your cars set in a fixed gear?
Ive solved this mainly by buying good tires. If Davide says it can be altered in the system I would go for that option first. Do not expect much help from Micro-Vett or Ansaldo.
What typ of Doblo do you have? a generation1 or a generation2?
I may have some spare parts lying around
I thought we were using the best tires for winter condition (e.g. Nokian) in Norway and I tried several types of wheels with and without spikes, so I am very interested in knowing what tires you use.
Since you had this problem only once I would also like to know what version of firmware the Ansaldo inverter is running (alternatively when your car was made, newer cars have updated firmware).
I tried what Davide suggested and as I wrote in my previous post it is not a sufficient solution, I could not really notice much improvement and he wrote to me that it would not solve the problem completely.
Attached is a picture of they Doblo and also a picture of the UM card (BMS card) that I need. Please let me know if you have one. Thank you!
(I am also interested in similar card for Fiorino and Mux-cards and charger).
