New guy here
the max volt on my bug 144v - 150 v right now it is set up for 108 v with AGM batteries . Honestly the AGM batteries are toast so I am considering 128 volts of G 2 Nissan Leaf batteries, looks like 16 modules or 18 modules for 144 v. Looking for a BMS or a couple BMS . The question is can I put a bms on a pack of say 7 or 8 modules and run the packs in series? Do I calculate the bms for the pack voltage/amps or total voltage/amps of the total batteries in the car ? BMS suggestions and sources needed no millionaire here, affordable
thanks
thanks
