I have been working on installing an aftermarket kit on a Prius to makes it into a plug gable hybrid. I have as input a 16s LiFEPO4 battery.
I have a problem however with the BMS that come with the kit. Cells #12/16 and cell #13/16 both read incorrect voltage (cell 13 reads .2V too high compared to the multi meter reading and cell 12 reads .2V too low). I am worried that the BMS will then "burn" these 2 cells by overcharging cell 12 and over-discharge cell 13.
I was wondering if there is any way I could re-adjust the BMS reading so it properly detect the correct voltage. Otherwise, would it be possible to maybe insert a low resistance on one or many balancing cable to compensate for this reading ?
I could also just buy a cheap BMS circuit without monitor but then I have no idea how I could trust such circuit without feedback.
The kit in question is an Enginer kit (bought a used one)
