Flooded Lead Acid Calculations - Range/Performance
7690 Views 24 Replies 9 Participants Last post by  pflipsen
A consolidation of notes from Kitty Rodden's presentation to the Peninsula Chapter of the Electric Auto Association, by David Coale.
What battery should I use in my EV?
This is the age old question; what battery should I put in my EV? There is no standard answer to this, it depends on what you want out of your EV. The old rule of "thumb" if you will, is the more lead the greater the range and the poorer the performance due to the increase in weight. It is also true that the higher the voltage the better the performance (acceleration and top end speed). This is of course also dependent on the type of driving and on the controller. Since these are fixed for any given EV, these generalizations are not too far off. Two designs illustrate this:
Long range: 96 to 120 volt system using 6 volt deep cycle batteries. This will give you lots of amp hours and weigh 976 to 1420 bls. This type of battery pack should last two to three years depending on the type of driving.
High performance: 96 to 144 and up using 12 volt batteries. If you use a starting battery your car will be light (400 to 700 bls.) and quick and your batteries will last about 3 to 6 months or less. If you use deep cycle batteries (12V) your batteries can last as long as one and a half to two years but the car may be heavier depending on the battery.
So what is the range in each case? Isn't that what we want to know; how far will my EV go? Answering this will help you decide what battery you will use.
To find out how far a particular battery pack will take us, we need to know how much energy is in the pack and how much energy the EV uses per mile.
Range = Energy in pack / (energy used per mile)
The energy in the battery pack (wired in series) is the amp hour rating times the pack voltage. The amp hour rating is how may amps a battery can supply over a given time. Most batteries are measured over a 20 hour period. This is a standard that is used to compare batteries with, and can be found in the specs. on most batteries. The 20 amp hour rating has to be adjusted for EV use. The faster one draws current from a battery the less capacity there will be. This is due to the chemistry of the battery and the internal resistance. Therefore the capacity of a battery at the 20 hour rate is more then the capacity at the 1 hour (EV) rate. The following is a table from Trojan Battery Company showing the conversion factor for finding the X hour rate given the 20 hour rate:
Conversion of 20 hour rate to X hr rate.
X hr Conversion
rate factor
1 .57 = Most commonly used value
2 .67
3 .74
4 .77
5 .82
6 .84
7 .86
8 .87
9 .89
10 .91
20 1.00
Note: these values will be a little different for each battery.
One can see from the table above that as you drive faster the range will decrease due to reduced available capacity. This does not take into account wind resistance which also increases with speed.
Now we need to know the energy or watt hours per mile that your EV gets. The table below lists some common EVs and their watt hours per mile rating.
Impact = 130 W-hr/mi (AC drive very good aerodynamics)
Metro = 160 W-hr/mi (PM drive good aerodynamics)
Metro = 200 W-hr/mi (DC drive good aerodynamics)
Truck = 350 W-hr/mi (DC drive poor aerodynamics)
This table was developed using several cars for each category traveling at highway speeds (60 mph). The numbers reflect the efficiency of the cars listed. With the following information the range equation for a smaller type of EV on the freeway would be:
RANGE = (20 amp/hr rating) X (.57) X (pack voltage) / (watt hours per mile of the vehicle)
Note: The above is the range @ 100% DOD, Divide that amount by 2, to get a 50% DOD range on your battery pack, I would try and not go lower than 50% DOD in order to maximize the life of your Flooded Lead Acid batteries. AGM/Gels might be more forgiving.
21 - 25 of 25 Posts
So how accurate was this in light of your experience with your conversion?
It's also fairly accurate with my experience on my conversion (http://www.evalbum.com/1974).
(110 AH batteries X .57 X 120V pack of 12V AGMs) / 325 Wh/mile * X .5 ** = about 11.6 miles useable range for my conversion.
* this number may seem high for a small car conversion but it's a real world value obtained using actual KwH I need to recharge the pack divided by the distance I have travelled (lower values are often based on some onboard instrument while driving at some constant speed but those numbers rarely account for changes in speed and driving conditions).
** based on 50% DOD which is all you can reasonably expect to draw from AGM batteries
Way pessimistic in my experience. I'm using my EV buggy as it is my only current lead powered EV. It is light, but very non-aerodynamic (this thing makes an aircooled Beetle look streamlined.) A steady 35 mph speed requires a little over 50 amps at a little over 120 volts.
(55 AH x .57 x 120 V pack of Optima YTs) / 325 Wh/mi x 0.5 = 5.8 mile useable range. Real world is more like 14 useable miles (21 city mile drop dead range with new Optimas.)
I'm looking at closer to 200 watt hours per mile and I find that Optimas can give up about 60% of their available amp hours when determining full range. You can expect to use about 70% of that and have a decent life if your usage is mixed with that point being the highest regularly used.
It is important not to rely on wall power to determine watt hours per mile. Charger losses and battery charging inefficiency losses can't be included into battery Wh/mi because that isn't power isn't used on discharge. I have to admit, buying a cheap used power meter and charging through it is a nice data point, but not for range and DOD calculations.
Weight difference may be the key here. It's my understanding that drag differences only make a big difference above 40 mph. I draw 80-90 amps at 35 mph with my Plymouth Colt (current curb weight = 2790 lbs; coefficient of drag on original was 0.36 - probably a little better now since I added a belly pan and I inflate my tires harder than recommended).
At what voltage? I'm running 120 volts so about 180 watt hours per mile at that speed. My actual driving average is a little higher and goes way up at freeway speeds. The car weighs 1420 lb. with 10 Optimas.
I'm also running 120V. I can do highway speeds but never have a reason to go over 40 mph and try to keep it under 35 (and given my limited range wouldn't want to go faster). I can't measure Wh/mile while driving at the moment; that's also why I do it from the wall. Your EV is about half the weight of mine, so I'm not surprised you get much better range.
21 - 25 of 25 Posts
