Elcon/TC 6.6kW charger, 50-198V for sale in perfect working order. I had it in my conversion and it's probably only done a dozen full charge cycles. CAN enabled, I bought it from Zero-EV (this one: Elcon TC Charger 6.6kW 50-198V - 46A - Zero EV) but not using it in my conversion any more. It comes with an extra set of heavy duty brackets in stainless steel for different mounting options, and two sets of unused connectors. I am also including the connectors I was using, so wired/crimped/soldered already and the original brackets it came with.
Collection preferred, but happy to discuss postage options or even meet you somewhere if you're not more than an hr or so away from E. London. Any questions please ask. Note this is a CAN-enabled charger. Works out of the box with an Orion BMS2, I used it on a 5xTesla module Hyper9 setup. Minor scratches to back surface, see photo.
Wood Gas Automotive exterior Office equipment Folk instrument
Circuit component Amber Electrical wiring Jewellery Cable
Motor vehicle Shelf Automotive design Bookcase Automotive exterior
Wood Tool Saw Metal Automotive exterior
Wood Circuit component Table Rectangle Gas
Wood Natural material Rectangle Font Fashion accessory
Asphalt Floor Road surface Automotive exterior Composite material
