Were they under BMS management? How do the voltages compare between cells? What charger were you using? Might be interested in them for my VW Rabbit, on near Long Beach, CA.
I originally had a charger/balancer supplied by Hipower, unfortunately I had issues with it from the start. For one thing it was 110 v 25 amps, so I had to have an electrician install a special plug, which limited my charging to that location. Also the balancing function never seemed to work properly.Were they under BMS management? How do the voltages compare between cells? What charger were you using? Might be interested in them for my VW Rabbit, on near Long Beach, CA.
