1 - 2 of 2 Posts
One used NetGain WarP 9 series wound brushed DC 9.25” motor. This motor was purchased new in 2014 (serial No. 401) is in perfect working condition. Brushes have plenty of life and commutator has good filming and shows no signs of visible wear. CE end has 3/8” aluminum mounting plate and 2ppt hub with proximity sensor for rpm measurement. Additionally, motor has automotive-style temp sensor to monitor brush temperature. Everything pictured is included.
Sales Brochure info:
· Series wound DC motor
· Rated voltage: 72 – 156V
· Maximum current: 1000 A
· Diameter: 9.25”
· Length: 15.9” (face to face)
· Weight: 156 lbs
· HP: 34 (continuous @ 144V)
· RPM: 5800
· Torque: 100 ft-lbs @ 500 Amps
· Shaft: double keyed 1.125” diameter
· Brushes: Dual wafer Helwig carbon red top
· Brush timing: Advanced for CCW-DE rotation (can be changed to neutral or advanced CW-DE)
· Insulation: Class H
· Terminal studs: ½”-13
· Fan: High efficiency 15 blade
https://www.ebay.com/itm/NETGAIN-WA...747024&hash=item216531485f:g:ihsAAOSwnhpdv1xX
1 - 2 of 2 Posts
