Ford, like other manufacturers, publishes information to assist companies which upfit commercial vehicles with special-purpose bodies or interior fittings. At Ford, this is the Body Builder Advisory Service. One document which recently became available is the presentation from the e-Transit Measuring Session on 2021 October 05.
In the process of explaining how to work with the e-Transit to add interior equipment (to the van) or to mount a body on the chassis-cab or cutaway, they show how the EV components are mounted to the Transit unitized body and structure.
It is apparent that Ford did not modify the Transit unibody to make it an EV, which means that whatever Ford did, a DIY builder could potentially do to convert an ICE Transit or similar vehicle.
- The rear springs and beam axle are replaced by an independent suspension and EV drive unit (the drive unit apparently the base Mach-E rear unit) mounted to the stock Transit structure by a subframe.
- (grey is stock Transit structure, light blue is subframe, blue-grey is suspension and axle shafts, copper is drive unit)
- The battery pack - apparently taken directly from the standard-range Mach-E - is mounted to the Transit's main frame rails (not the rocker area) via a large framework which includes crash energy absorption structures on each side, replacing the fuel tank and exhaust system.
- The engine and transmission are replaced by the auxiliary components (presumably mostly from the Mach-E, given the battery choice) mounted to a subframe, with the spare tire underneath.
- the EV adds approximately 600 pounds of curb weight over the base 3.5L PFDI V6 engine configuration
- the Transit has a vacuum brake booster (not a Hydroboost or iBooster, for instance), so the EV has a vacuum pump
- the spare tire is relocated from the rear to the front, apparently to protect the EV drive unit in a rear collision (and perhaps to absorb energy in a front collision)
- while promotional material lists a range of 126 miles, that is only with the low roof; the medium and high roof versions have a range of 116 and 108 miles, respectively
