Hi all. New here. I have an electric ATV build in the works. I have my battery pack, Leaf Motor/Inverter(from different cars{2015\2017}), VCU(Thunderstruck v3.1), and amalgamation of wires. I have the motor spinning with a pedal throttle. I have tried multiple configurations with the FNR switch. I have tried those configs with FR enabled\disabled and FNR enabled\disabled in the VCU firmware.
I cannot get the motor to change directions. I'll include some pics. Hopefully something is obvious to someone with a little more know how.
Disclaimer: I did have to repair the wiring harness at the resolver location. You can probably see in one of the pictures that it is not normal looking.
Any help would be greatly appreciated! Any questions you have, I will do my best to answer. I am understanding enough to be dangerous.
EDIT: I had the brake set to "hall." I set it to "off" in the vcu and now I have Forward and Reverse!
219.5 KB
157.4 KB
170.8 KB
192.8 KB
