Frankencar Build Thread Cont.
Long overdue update -
If anyone cares, I'm sorry that I'm bad with keeping the build thread up to date, plus a major problem with starting tangents (no more CNT comments here!)
So I've got all the welding/fabrication done, and due to a slight curvature of the underlying frame, I will be fitting seven batteries in the rear box and five in the engine bay. The rear box has been painted with truck bed liner to make it nice and tough, and the seven batteries are laid in, just awaiting wiring and the watering system. The box has fans on two sides, which also need to be wired. Currently working out details so the fans current will connect when the gas door is open.
Speaking of the gas door, that's done too. I've installed a 40 foot cord reel on it's side poking out the gas door (cut down to maybe 30 feet now) and put a male plug on the end. So instead of an extension cord, I just pull out the cable, and reel it back in when I'm done! I like it.
To make a very very very long and extremely painful story ridiculously short: The motor is almost mated perfectly. Everything is linking up, but when I try to run the motor, the clutch is slipping. Next step is to pull the motor out (for the seventh time, I think) and reduce the spacing between the flywheel and pressure plate, tighten that guy down, reinstall the motor, and bleed the clutch.
Also, don't use ElectroAuto (I told you its a long story but I'm NOT going into it right now. I'll do a post on my blog at frankencar.org in the future about it).
Next goal is to get the motor mounted and working, then get the rear box finished, then I'll start on the safety fuses, main contractor, etc. Getting excited! If anybody has cautionary advice for this point in a conversion please let me know. Otherwise, I'll try to keep you posted!
