Build was 98% complete including:
Soliton Jr Controller
Orion BMS
TCCH-H145-16 Charger
7" Prestolite Motor
Insulated and heated battery boxes.
Cabin heat
Vacuum pump
Public charge station compatible
Simple 240V charge cable
Canbus Integration.
- Original tach shows battery amps
- Tach lights show low battery bms errors etc.
- Gas gauge shows batter charge(needs some work)
- Torque app shows detailed info
Mechanical work is solid. Motor is smooth.
I allowed batteries to drain and they failed after I attempted to revive them. The front ones melted down. The front box will need to be cleaned up and re-insulated/painted. The BMS will neeed to have fuse replaced by Orion.
Batteries were 96 - 40ah High power cells 2 parallel 48 series
This car worked great for me for a couple of years. Drives in town in 3rd gear and highway speeds in 5th. Longest range was about 80km.
Located in Kingston Ontario
Make me an offer. I think about $5000 cad is reasonable.
Orion BMS
7" Prestolite Motor
Cabin heat
Vacuum pump
Canbus Integration.
