I am selling my ACGTX20 motor. It's a tested good motor straight from Solectria, then garaged, but does need one Andersen power connector. Here are the specs:
3 Phase AC
12 KW Nominal
42 KW Peak
70NM torque peak
4,000 RPM Nominal
12,000 RPM peak
I do not have a controller for it, but the Open Source AC controller project should be a nice fit. I had plans to use the new Open Source AC controller with this motor, but my next EV will most likely end up being a DC system. Also good if you need to replace a motor from a Solectria vehicle.
Asking $2,000 USD.
3 Phase AC
12 KW Nominal
42 KW Peak
70NM torque peak
4,000 RPM Nominal
12,000 RPM peak
Asking $2,000 USD.
