Hi,
I have a electric motorcycle with a Curtis 1239e and a AC20 motor. Now I am trying to adjust the parameters on the controller.
I have adjusted the slipgain, and it is optimal at 1.9. Also trying to get correct Base Speed but the captured value is ~4800 rpm... As I understand it is high. Might be correct but I wanted to see if someone else has tested my combo and got similar values?
/M
/M
