Absolutely not. I like your confidence though!Basically if I had 5 or 6 of the optima batteries then that's the same a the Tesla battery pack?
An Optima YellowTop D51 has a charge capacity of 38 amp-hours (when discharged very slowly, much less in EV use); at 12 volts, that's 38 Ah * 12 V = 456 Wh (or 0.5 kWh). And that's kWh, not kW. You would need more than 100 of them (weighing much more than a ton and costing about $25K) to hold 50 kWh, and perhaps 200 (over two tons, over $50K) to deliver that much energy at the relatively high discharge power of an EV.I want to use an optima yellow top, specifically a d51, and can't seem to find the wattage/kw. From what I've found it's maybe 9kw? that doesn't sound right though. Basically if I had 5 or 6 of the optima batteries then that's the same a the Tesla battery pack? Is that right? I'm not sure but I think im missing something.
I realize now that this battery choice came up last year in the same member's other thread:I want to use an optima yellow top, specifically a d51...
So, repeating this point:Shouldve been more clear, was thinking about lithium ion, probably optima for the weight...
Classycrusader, you seem to have the impression that Optima batteries are lithium-ion, but they're not. They're a specific construction of lead-acid battery called "AGM", meaning "absorbed glass mat", which means that the electrolyte (acid) is soaking a mat of glass fibres between each pair of lead plates, rather than just being an open pool of liquid.Optima Yellow-Top batteries are AGM lead-acid batteries, not any kind of lithium-ion battery.
You say "all duly noted", but did you actually read any of the responses? You're still talking about using Optima batteries, which you have repeatedly been told are not lithium-ion. You're asking again 'how much an Optima D51 would give', but I worked that out for you already.all duly noted. what would be a good lithium ion battery? I'd like to use car batteries because they're more easily refurbished when they go dead.
Second, how much would, let's say, the d51 optima give?
Try reading the post that I already wrote for you a month ago, and pointed out to you again today, in response to the first time that you asked this. But don't ask for clarification if you don't understand it, because you're certainly too much of an asshole to bother helping any more.calm down im just asking for reference, ill look into the real lithium ion but as stated I'd prefer lightweight car batteries because it's easier to refurbish them and coming from the ICE world I know that optima is the best in terms of weight.
I can't seem to find the exact numbers I need for the optima d51 atm.
I suggest that you burn or return your engineering degree. A first-year engineering student in any discipline knows the difference between power and energy, and can deduce the range per D51 battery from the earlier posts.And like I said, I am not educated in electricity, I'm a mechanical engineer, not electrical. That's why I came to you for help. If I understand what kind of range I could expect (roughly of course because of factors) with one good car battery I can work out the rest through reverse engineering. That's why I came to you, for help, not flaming.
I already did work out and explain everything that you're asking - it's all there in this thread. Good luck with having other people do your project, and repeatedly explain to you what they did for you.Apparently you can't so you're not much better, let alone helpful
You are totally off track. I'll try to help.calm down im just asking for reference, ill look into the real lithium ion but as stated I'd prefer lightweight car batteries because it's easier to refurbish them and coming from the ICE world I know that optima is the best in terms of weight.
I can't seem to find the exact numbers I need for the optima d51 atm. And like I said, I am not educated in electricity, I'm a mechanical engineer, not electrical. That's why I came to you for help. If I understand what kind of range I could expect (roughly of course because of factors) with one good car battery I can work out the rest through reverse engineering. That's why I came to you, for help, not flaming.
I use Nissan Leaf batteries. Check out my thread I have been documenting my build for the better part of a year.im trying to but everyone isn't really giving any data, info, or help. What batteries would you recommend? I remember talking to someone that had a square back and they said each car battery for them was about 10 miles worth of range. Probably because of the low weight of the car and less mechanical loss being rear engine rwd
