1 - 20 of 20 Posts
So a while back I picked up three 96 volt presolite motors and a General Electriv EV-1 controller was included in the bundle.I have been looking over the posts here and looking at a ton of google results, and I am still not sure how to connect this damn thing to make it work. I am very new to EV and have not a conversion as of YET.
IS There anywhere that anyone knows of that has a Dumbed down version of illustrations on a simple connection setup for these things?
I can read schematics and blueprints and things of that nature, but everything I have looked at just seems to have so damn much going on. I just want a simple on/off and accelerator.
Is that possible? or something close to this simple? I am sure a brake switch is needed and something else I am not thinking of at the moment.
Motor vehicle Automotive tire Automotive exterior Wheel Automotive wheel system
Looks like they are, using some tricks:
I feel like you got to confusing this with something else, you got some links with documentation I can see on what you are referring to? Nothing I have found says anything like what you are saying here. these things are listed as being commonly used in Forklifts as well.
this is one of the first pages That pulls up on a quick search:
When you are using 50 year old tech, that includes use of HEAVY reactors to fake out the SCRs ("tricks") for use on DC, a 4 month old thread is as up to date as it gets.
Yes, they talk about forklifts, which are perfectly fine carrying all that iron in the circuit around.
They also have schematics in that thread, which I mentioned, that include the pump motor and EV-1 connections.
Just because you have it doesn't mean you should use it.
Discussion Starter · #11 ·
I have this EV-1 thing in my 36V forklift. The truck itself is dated 1981, so quite old stuff. It is possible to do what OP wants, but the question is if it's worth doing.
For me it is, as its just a learning experience and I already have it. Its not going to go into a car just want it for around the ranch, in a small UTV
So do you have any specific question at this time ? I've been some over those schematics when my forklift stopped running, it's not a complicated system to wire. Also there is a person on this board who is quite experienced with those systems in forklfits, I will find his username shortly.
Here he is Forklift Guy
Discussion Starter · #13 ·
looking over the schemactics I found the throttle input and switch power on and off. I see a lot of other input devices that although I can see being needed on a forklift or other various large pieces of equipment. My needs are far more simple, in that can all that be done away with and just wired for on/off, Brake switch and Throttle, Also I only need forward. the transmission has reverse built into it.
I think your talking about "Forkliftguy" I have messaged him as well waiting for a responce.
You should wire the stuff you need, then use their troubleshooting steps when/if the motor doesn't run. You will likely need to put jumpers on some of the inputs that aren't in use, but you will be able to figure that out practically.
What are you going to stuff this setup into? Should be pretty simple once you find the needed throttle and brake. Test it on a bench to be sure it works and be sure to tie down that motor tightly before giving it power. I'd suggest you connect it up to 12 or 24 volts only for testing. They do work and were used in vehicles other than forklifts as well. You don't need AC to turn on and off an SRC. Gate drivers are needed.
Discussion Starter · #19 ·
Originally it was going to go into a VW Sand Rail Frame, but wife asked me to trim down my projects. I have a totally different controller for it thats straight forward and easy to set up, But I want to see if I can get this one working.
And Yeah I have spun up the motors with 12 volts already, They are "new" OLD stock and the brushes look new so I am going with the description I was giving is close to accurate. :)
I currently dont have anything to put them in so They are just a little side project to play with for now. I have three motors and one current tech controller and this old one.
1 - 20 of 20 Posts
