i've been trying to research electric vehicles thanks to the inspiration of white zombie (all hail white zombie!!!) on PBS and have trouble getting my questions answered with keyword searches etc.
try to understand motors and output, and one place talks about watts, another horsepower, another volts or amps etc. is there some place that converts all of those ergs between each other?
originally, for fun, i tried to imagine a vehicle that could beat the zombie and came up with the idea of converting a sand rail. you can't get a much better power to weight ratio than that, can you? then after seeing how much batteries, motors & controllers cost, even for daily drivers relegated the idea to daydreaming.
my "car" right now is a pair of bicycles (so happy my obvious name hasn't been used here yet) and i haven't had a car since 1993, but bikes & busses are limited in range and schedules. i'd like a mode of transportation that lets me get groceries in less than 3-4 hours & catch midnight movies etc.
trying to find used forklift motors is impossible too and any time you do find places that have them, they're only part numbers. you know the routine. i'm surprised no one has decided to go into business refurbing forklift motors as it could be profitable.
right now, i'm starting to think that at least for transportation, i might be able to get a vehicle if i think small. i'm picturing taking a 110cc mini-buggy and converting that motorcycle style. i'd like to turn one into a 55mph/50 mile grocery getter with regernerative breaking and possibly solar cell supplimented. i figure that going with a chain drive vehicle alone should make things much simpler and cheaper and actually DOABLE. if it could also drag race, that would be cool too.
one of the ideas i had was to run a PAIR of pancake motors on each side of the sprocket for increased HP/torque (there goes regenerative breaking) without using large expensive motors. i've never seen that done. would there be any advantages or disadvantages to that? i'd think it would lower the load on each motor as well as offer higher current capabilities much like the stacked motors in the zombie.
without relying on a cramped motorcycle frame, it should be easier to accommodate batteries without gaining weight. i even imagined a battery trailer for an EV somewhere along the line and today toyed with the idea of a solar steam engine. really, i like the idea no one seems to talk about... hydrogen conversion which should be so much cheaper & practical. that technology still hits the range barrier but should be an easier transition globally. more than 10 years after seeing a stock ford econocar converted to hydro with a couple thousand in plumbing, i'm surprised that hardly anyone is doing that. a hydrogen powered buggy could be both fast & cheap.
this is an electric forum though and that tech seems easier to DIY so i'll keep my interest there.
any opinions on the idea of converting a single seat buggy into an electric go kart? as you're all familiar with the math, ROUGHLY how many volts/amps and what size motor(s) would i need to get a highway capable ride? think a conversion is doable for under $2000? would it be impossible to get such a vehicle registered once properly lit & speedoed etc.?
if it weren't for fear of insane fabrication costs, eg. A arm suspensions etc. i'd love to design a mini frame with the simplified angular lines of a rail buggy instead of the goofy & excessive framing on chinese mini buggies. sadly, rail buggy frames are cheap, but getting them rolling isn't, but minibuggies are dirt cheap. (anyone want a 110cc motor? LOL)
