I got the DC cable from a crashed Ampera and it is 35mm2 with a shield. That is why it looks like 50mm2.Wondering if anyone knows what the Volts use for cabling. I know both cables are jacketed with an isolation detector but I'm lightly wondering after watching the Teslonda build if upgrading the conductors would improve performance on a stock Volt. The mid pack fuse is 350A.
Thanks.
I think 350A max is a good enough estimation. Volt power inverter is capable of 115kW at least. So 350V x 320A gives a good enough power.
A
