Anything is possible with bags of money and time.
The question is..."why"?
Things may be changing in the ******* (red neck as one word gets censored, but fuck doesn't) world if you look at the comments here:The other reason being I'm half a red neck from the sticks and live in the world of lifted trucks, 4x4s and everything else that goes with it.
Yes... but the Highlander has a hybrid transaxle to supply the electrical energy, and a battery to store a bit of it. It's not clear where Babybluegen2 intends to get the power for the rear motor(s).My highlander is exactly what you are describing. The OEM hybrid system includes the MGR which is just an electric motor and a differential with a bunch of reduction...
Well as long as it's still a prius... they are the same just rated at 250kw instead of 80. Exact same inverter design minus a small section for the rear wheels. This is easily added with another prius gen 2 or 3 inverter.Yes... but the Highlander has a hybrid transaxle to supply the electrical energy, and a battery to store a bit of it. It's not clear where Babybluegen2 intends to get the power for the rear motor(s).
It's just a question of capacities: everything should be larger (MG1 and the battery being the relevant parts) in a Highlander or RAV4. I suppose it's not a big concern for very low-traction conditions and brief periods; I don't know if the current "eAWD" Prius has any greater capacities than the base FWD version.Well as long as it's still a prius... they are the same just rated at 250kw instead of 80. Exact same inverter design minus a small section for the rear wheels. This is easily added with another prius gen 2 or 3 inverter.
The 80kw generator in the prius is capable of powering it (50kw rated), it would help massively to replace the stock NiMh with some A123 cells at the very least. Prius is 3 LFP cells, highlander is 4 to direct replace the nickel blade modules.It's just a question of capacities: everything should be larger (MG1 and the battery being the relevant parts) in a Highlander or RAV4. I suppose it's not a big concern for very low-traction conditions and brief periods; I don't know if the current "eAWD" Prius has any greater capacities than the base FWD version.
