Really? Because the person who wrote about it did not build it.
There's a better reply, ty.
Really? Because the person who wrote about it did not build it.No offense, but why don't You ask the guy who built it, or the guy who wrote about it?
There's a better reply, ty.Probably, has an electric clutch from an A/C pump, or something similar...
....the battery charger is dual 12volts at 30amps / 96volts at 30amps, typical cost for single charger at 96volts at 10amps cost is about $600
I believe the Bradley GT is a kit car. Which means that whoever assembled the car used whatever skills they had when wiring it.Why not try to acquire a copy of the original Bradley GT wiring diagram?
Yes, you are correct. The seller purchased it that way. I'm trying to figure out how they set it up. I was thinking that the generator functions only when there is a load on it, but how is it done electronically, or is there some type of clutch as described above.Point taken. When I compared yours & eBay photos I assumed they were both Bradleys.![]()
an alternator will go as high as 3000 volts if not regulated.
same power which means the current is less.
to hook it into the motor and throttle control, takes some doing.
basically you vary the field so provide the output you want. that is the easy part.
there are a couple of solutions both involving a micro-controller.
I learned about this from Auto repair manuals and products been around for a while.Any links? Schematics? ...on this? Thanks.
