21 - 22 of 22 Posts
Discussion Starter · #21 ·
Hello again!
I've been trying a lot with slcand, ip, ifconfig and such on my computer with the motor running slowly and the CANbus seemingly correctly connected. Whatever I try, nothing comes out. There are those CAN speeds (-s1 (20kbps) to -s6 (500kbps)), whether or not it is can or vcan, and maybe more variables I'm not aware of. I've tried all the CAN speeds. My USB-CAN adapter has an "ACT" LED, I assume this stands for activity. This lights a solid orange/red.
I'm starting to suspect the controller does not send CAN signals at all. The controller was pulled from a G-Wiz/REVAi which did not use the CAN interface, so I would not be surprised if CAN is turned off in the controller. As far as I know, the only way to enable it is to buy the 1313 or 1314, which cost hundreds of dollars. Is this the case?
I'm also looking at the Curtis 840. I still want the data into my own computer, but the 840 points to the fact that the serial connection also can give me the information I want. If this is the route to go, can you guys point me to how I can read and parse the serial data from the Curtis 1236 on a computer?
You can buy an Arduino and a cheap SPI to CAN module and connect it with arduino.
SPI 2 CAN module
A general example to send a NMT message via arduino to curtis to put it into operational state.
C:
#include <SPI.h>
#include <mcp_can.h>
const int spiCSPin = 10;
int ledHIGH    = 1;
int ledLOW     = 0;
MCP_CAN CAN(spiCSPin);
void setup()
    Serial.begin(115200);
    while (CAN_OK != CAN.begin(CAN_500KBPS,MCP_8MHz))
        Serial.println("CAN BUS init Failed");
        delay(100);
    Serial.println("CAN BUS Shield Init OK!");
unsigned char stmp[2] = {0,0};
void loop()
  stmp[0]=0x01;//Operational state
  stmp[1]=0x00;//target node ==> set 0x00 for all nodes
  Serial.println("In loop");
  CAN.sendMsgBuf(0x00, 0, 2, stmp);// COB-ID, 0 for standard ID and 1 for extended ID, 2 is the data length , stmp is the data
  delay(120);//heartbeat message rate
A general example to send a SDO message via arduino to curtis to retrieve Key Switch Voltage
C:
#include <SPI.h>
void recv()
  unsigned char len = 0;
  unsigned char buf[8];
  unsigned char a,b,c;
  int a1,b1,c1;
  if(CAN_MSGAVAIL == CAN.checkReceive())
        CAN.readMsgBuf(&len, buf);
        unsigned long canId = CAN.getCanId();
        Serial.println("-----------------------------");
        Serial.print("Data from ID: 0x");
        Serial.println(canId, HEX);
        for(int i = 0; i<len; i++)
            Serial.print(buf[i]);
            Serial.print("\t");
            a = buf[4];
            b = buf[5];
        a1 = (int)a;
        b1 = (int)b;
        c1 = b1 << 8 | a1 ;
        Serial.print("\nKey_switch_voltage:");
        Serial.println(c1);
        Serial.println();
void setup()
        delay(100);
unsigned char stmp[8] = {0,0,0,0,0,0,0,0};
void loop()
  stmp[0]= 0x40; //Read Dictionary Object
  stmp[1]= 0x4D;//second eight bytes of hex value(sub index)
  stmp[2]= 0x32;// first eight bytes of hex value (index)
  stmp[3]= 0x00;
  stmp[4]= 0x00;
  stmp[5]= 0x00;
  stmp[6]= 0x00;
  stmp[7]= 0x00;
  CAN.sendMsgBuf(0x626, 0, 8, stmp);//... , 0 for standard ID and 1 for extended ID, ... , stmp is the data
  delay(100);// timeout
  recv();
21 - 22 of 22 Posts
