1 - 1 of 1 Posts
Acne scarring is a reminder that one has successfully made it through a tough bout of acne. Once the acne seems to be gone, you should start working on resurfacing your face if you should think that your appearance is lacking, or even if your self esteem seems a little bit under the weather lately.
If you got out lucky, you will only have mild acne scars. You can treat mild scars by yourself if you feel confident enough. Use strategies such as sauna treatment, massage therapy, and drink plenty of water over the span of a month to see how well you improve. If you did the treatment correctly, you should start to see your face becoming more smooth.
Next up on the ladder we have chemical peels. Chemical peels, however scary they may sound, are also fairly tame. Chemical peels only take off a small layer of skin at a time, so they too take a long amount of time to get results from. Acne scars will slowly become exfoliated and disappear over time, but only mild to moderate cases of acne should investigate this approach.
A more advanced form of the chemical peel is the dermabrasion. A dermabrasion is a technique in which a metal brush or other surface is used to scrape away the top layer of your skin. It can be somewhat uncomfortable to go through, but it takes off more skin than a chemical peel and should be considered more effective. Your physician may require that you stay shielded from the sun to prevent sun damage.
When all else fails, we can result to lasers. Laser treatment is the most effective option, but it is also the most costly and extreme. Laser treatment can selectively burn away at acne scars, so it is more targeted. Laser treatment also hardens layers of skin below the surface of the top layer, meaning you will have a smooth appearance once the current layer is shed. The recovery time is long, but well worth it.
So what's the best form of getting rid of acne scars? We can all agree that preventing the scars in the first place is the best idea. Even if you have acne that seems like it won't go away, there are options in prescription medications that you can investigate. Some are rather tough or frightening when considering the side effects, so don't be scared to try and wait out the acne and see if it improves by itself. More on beauty tips on secrets in health
In Conclusion
Acne scars, thankfully, can be fixed with a bit of treatment. Embarrassing memories of one's childhood can be swept away with as little as a week or two. Your budget and your severity can be surveyed to see what is best for you.
www.morehere.org/entry.php/14942-Color-Protect-and-Correct
1 - 1 of 1 Posts
