I have a weird problem... I just finished getting the car put back together after building a new pack, adding AC, power steering and upgrading the charger to the EMotorWerks MiniSmartCharge 12K. The EVSE reports a GFCI fault if I I have the battery connected to the Soliton1. If I disconnect it, it charges fine. It never did that before I rebuilt everything. I also previously used the regular SmartCharge 12K.
With the battery connected to the Soliton1, I can measure negative pack voltage from chassis GND to pack-. It would seem to indicate that pack+ is shorted to chassis somewhere... But when I disconnect the Soliton1, the apparent short goes away. I've traced everything I can and there is no short anywhere else. Does the Soliton1 PGND or SGND need to be isolated?
When not charging and the Soliton1 connected as normal, the car drives fine.
Any ideas?
Any ideas?
