Aloha, I got my TS 200ah used lifepo4 in and they
all tested at about 3.29 to 3.33 after sitting for 6 months.
BUT I have a problem. I have a chance to get some used TS 400ah
really cheap and now thinking of paralleling the TS200's by two
and using the 400's and run in series.
Problem is that 400ah are monsters (30# each) and will be
much overkill range for my 1700# (without batteries) Yaris.
Soooo, how low a voltage would you go on existing 2/0 wiring?
I could go heavier wiring from the 1/2 pack in the rear
to the pack 1/2 in front and to Zilla and motor.
I think I will have a total of 78v using
24 batteries @[email protected] average V.
With my AGM Optimas @ 168v @ 130v running sag.
I was using 45 amps at 45mph. So if i use 100Amps
at 45-50mph continually with 1/2 voltage,
will that be too much continuous current for the 2/0?
Francis
Francis
