Great info above by MM! As for the mechanicals, it's a bit like a jigsaw puzzle if it's something strange (like a Borg-Warner T-85 with OD), but there are many off-the-shelf adapters for some common trannys, like a Tremec 5-speed, which will also give you an overdrive.
You'll probably only use a few gears...start out in 2nd or 3rd, then maybe shift higher for highway speeds. The thing is, you won't need to slip the clutch because electric motors don't need to idle like a gas engine. Some guys don't even put a clutch between the motor and tranny, just a straight coupler. Having a clutch is slightly safer because there's another way to disconnect power to the wheels, it makes the car seem more conventional to drive, and gear changes can be smoother if you're not a wizard with the stickshift. Clutch vs. no clutch is one of the big debates in the world of EVs, lol, and some cats get very passionate about their choice, hehe.
In many ways, a motor swap to make a car into an EV is very much like an engine swap in a gas-burning hot rod (an electric motor is a "motor", and an internal combustion engine, or ICE, is an "engine", in more technical terms).
You remove the parts related to the old unit, and fab/build/adapt some parts to make the new unit fit, and give it everything it needs to work. If you understand how a cordless drill works, an EV is very similar, but more powerful. The higher power needed to move a car needs respect because just like gas cars, there are forces that can burn/injure/maim/kill/etc. Just be as careful and respectful with an EV as your 700hp dino-burner, and you'll be fine, lol!
The AC-50/51, or whatever else you choose, is simpler to mount than any V8. You connect up the motor to your choice of trans with an adapter plate...Check with CanadianEV for off-the-shelf adapters, EVWest.com, EVTV.com, (or many others), then fab up some mounts from the motor to your frame. It's surprising how conventional it will seem to someone who builds hotrods.
Batteries and battery boxes are like the fuel tank(s). The motor will be a lot lighter than the engine, but the batteries will be heavier than a fuel tank. With current technology...you may come out even on weight from the old ICE, especially if comparing to a monster engine. Depending on what batteries you use, and how many of them, you'll come up with places to put them that are safe and secure. It's super cool that you have some flexibility with EV components...you can make a car handle much better because you can put batteries low, and in different spots to balance the car.
I've included some photos of my T-85/R11 tranny, ready for its adapter plate. I did use the clutch, FWIW. I know a guy who didn't in a 60s Falcon van and he's happy too. We'll see how it goes, lol...Good luck!!
183.5 KB
214.7 KB
