Hi Kyu,Hi all,
I am trying to charge a 350V Li-ion battery from enerdel with NLG512 charger.
This is my first experience charging a battery for EV, so problems expected but it's bit frustrating from the beginning.
The charger is connected to the mains 208V and the monitoring program shows
it has 301.xx volt in the charger mains.
When the main switch of the charger is closed, a solid red led is always on and does not make any voltage to the output. It seems something is wrong with the charger.
I desperately need some help here. Any suggestions and comments are welcome.
Thanks,
Kyu
This is a Brusa, right? Do you have the manual?
Regards,
major
