Heat lamp to warm batteries
1723 Views 6 Replies 5 Participants Last post by  pm_dawn
I tried a heat lamp this afternoon to improve the range on the cold run home.
It did make a little improvement.
Tonight I am letting it run all night to see if it helps in the morning.
Simple enough, time will tell.
1 - 7 of 7 Posts
sounds like a bad idea that may melt battery cases. ;) other issue is that without a box and insulation your batteries will radiate all that nice heat rapidly. try some heatline and a space blanket!
G
On top of that pretty wasteful of electricity.
Maybe you could adapt a standard automotive battery warmer.
Well, it did make a difference. I didn't have to use a lower gear on the big hill going to work. The rest of the day it is in the shop, so the lamp is not needed.
I am looking for a small heat blanket to use over them, but haven't found any.
No problem with heat damage as it is only a small watt lamp.
When I get the second pack inside the car, the oil heater will take care of them.
Just experimenting, without breaking the bank.
Sounds like a good experiment to me. Now you know effectively what the difference is in practical performance.
I know it is a lot of work but since heat rises, you should put the heat blanket under the batteries to get the best heating. then insulate the sides or the whole batterybox.
Regards
/Per
1 - 7 of 7 Posts
