1 - 3 of 3 Posts
Hi new to the forum and after a bit of advice, i am building my grandson an electric car using the parts from a mobility scooter, it has a PG Drives Technology D50746.04 controller, what i would like to know is there any way to reprogram the controller so that i can use a simple on off switch as a throttle, as it is now if you disconnect and re connect the power you have to reset the unit before it will start, thanks in advance Graham
1 - 3 of 3 Posts
