Hi everyone,
I am working on a 2000lbs electric vehicle using the Curtis 1238 Motor Controller and AC 50 Motor powered by 96 volts lead acid deep cycle.
I want to have the all the electronics in a box and have panel mount circular connectors for 1/0 cables so I can disconnect and connect from the box easily. 2 contacts for the battery, 3 contacts for the motor.
My question is what continuous and maximum Amperage rating do you recommended for the 1/0 connectors?
Or, what is the max and continuous amperage a 1/0 cable can withstand?
Please and thank you.Or, what is the max and continuous amperage a 1/0 cable can withstand?
