1 - 11 of 11 Posts
Hi I'm trying to find a good powerful motor for a electric car conversion.
I'm on a budget so I'm sticking to DC Motors salvaged from industrial machines or forklift trucks.
I had my heart set on a series wound motor but them came across this permanent magnet motor (see pics)
Would this be powerful enough to push a Mazda RX8 to 60mph?
Also would I need a specific type of controller for this motor not being series wound?
Thanks for your help :)
Regards
Jon
Sent from my F8331 using Tapatalk
Thanks so much for your reply
Forgive me If I'm getting confused here, I thought the bigger the motor voltage the more powerful the motor is?
What spec should I be looking for?
Thanks again for your knowledge
Jon
Voltage and current are both pretty much arbitrary in isolation.
Higher voltage means needing better insulation and sturdier contacts. Higher current means your wiring has to be thicker to minimize resistance.
Most DC motors repurposed for EV use are at least 9 inches in diameter.
Hi J-D
You need to read the thread on using a forklift motor - I know it's long but skim your way through
Very short summary
For a car you will need a 9 inch or 11 inch diameter motor
It will weigh between 60 kg and 100 kg
Most will be 36 or 48 volts - and rated at between 6 and 12 kW
You will need to operate them at above 140 volts
Thanks so much for your replies, this is very useful information.
Yes I did see the forklift motor thread but like you say it's very long winded and I started to confuse my self.
Would you guys recommend series wound or direct magnet motors?
Thanks again
Jon
What do you mean by "direct magnet"? If you mean "permanent magnet"... when people refer to "forklift" motors they generally mean series-field brushed DC motors. There are many brushed DC motors with permanent magnet stators, but likely none available which are large enough to use to drive a car.
The 1900rpm motor speed may require an expensive solution.
Your max wheel speed is likely to be about 1000rpm, depending on your tyre size and max vehicle speed. Most rear differentials have about 3:1 to 5:1 ratio and you'll need to add some other gearing to raise the propshaft speed above the motor speed, or be satisfied with a 50km/h top speed.
Hi,
The RPM/speed is solved by running higher voltage. That's something you'd likely want to do anyway to increase power.
That looks like a fine motor and would likely serve you well, but...... It appears to be the hydraulic pump drive motor. Therefore two big obstacles for use in conversions. It is unidirectional. Right for you? It has an internal splined shaft. A bitch to couple.
Regards,
major
Discussion Starter · #11 ·
Hi Major
Thanks for your reply :)
So to increase voltage to attain maximum speed, am I assuming I'd have to increase my system voltage?
For instance 14x 12v batteries in series to make 160v ?
Ps could buy a spline shaft I guess
1 - 11 of 11 Posts
