1 - 11 of 11 Posts
Hello community,
I have a Geo Metro electric conversion that needs its batteries upgraded. Currently installed are twelve Walmart branded 12 volt 114 amp hour deep-cycle lead-acid batteries. They got toasted trying to climb home. The road to my house has about 1/3 of a mile of 22% grade and nuked the batteries. It is an interesting feeling and experience climbing that hill as you can feel the electricity get pulled from the core of the batteries to the motor. It made it once but the second time had no chance of hitting the half-way mark and the brakes could not hold the weight. Thankful for my superb driving skills :rolleyes: :)
Anyway... I would like to upgrade my batteries to be able to use the vehicle. My aging CRV does not get very good gas mileage and need to watch the budget commuting to and from employment.
Have been interested in buying a salvaged LEAF or similar EV to scavenge the batteries and resale parts. That seems like the more economical route versus buying new "drop-in" batteries.
So this is why I come to the community. Looking for help in the calculations of what I will need. How many LEAF batteries? If I do the "drop-in" LiFeOS4 do I just match the number of batteries I currently have? What other alternative solutions may be out there?
Here are the details of the EV:
Motor: Netgain Impulse 9" motor
Controller: Open ReVolt 144 volt, 500 amp
Batteries: twelve 12 volt 114 amp hour deep-cycle lead-acid
System Voltage: 144 volts
Chargers(2): Quick Charge Octopus-AGM 10 Bank Charger
Quick Charge 2 Bank
http://www.chargingchargers.com/quick-charge/mb1210x2.html
DC/DC Converter: Kelly HWZ Series 144V TO 12V 300W
Instrumentation:
PakTrakr Battery Monitoring System, which monitors instantaneous
voltages of each battery in the pack.
Paktrakr Current Sensor, which monitors instantaneous
current delivered by the battery pack.
PakTrakr ES1R automatic logging serial interface for
recording instantaneous battery voltages and current.
The recorded data can be downloaded to a PC for detailed
analsys.
http://www.mightyboyev.com/PakTrakr 800.htm
Bluetooth RS-232 adapter for use with smartphone app
to display dashboard metrics on your smartphone.
http://www.usconverters.com/serial-bluetooth-adapter?zenid=363893a35f5f08d888f59851b2bbb07b
adapter port, which allows it to accept a standard
Level 2 charging station J1772 plug.
And finally any suggestions on proper battery disconnect? Would like to remove old dead batteries so I can push the card around the yard and avoid potential damage from leakage etc.
Thank you in advanced!
I would suggest a Chevy Volt pack - you can get them for about $2000 and while on paper they will have the same capacity as your lead in reality you will get double the capacity
Thanks for the reply @Duncan. I see they are a few thousand for the battery pack. Which is totally reasonable since I figured doing the drop in replacement would be at least $12k if it was a one for one kinda thing. If do go that route is it a simple plug 'n play or is going to be more involved adding other components and modifications?
I suggest you read this thread - I know it's long but there is some interesting stuff
The Volt battery is 9 modules - 7 off 2 kWh and 2 off 1 kWh
It's not difficult to re-organise at the module level - going below that to the cell level is nearly impossible
I have found you can go lower voltage if needed to add up right amount or cheaper to use less batteries
I got rid of 18 6v for 108v
now run lithium at 96v (120v controller limitation) and its alot faster and climb hills better without all that weight
not sure if better to use more batteries at lower voltage (6 at 20v vs 5 at 24v) to get closer to 120v or leave it at 96v with (4) 24v batteries ????
120v is max for old curtis controller and don't want to blow that up
im using fiat 500 batteries for the jet industry escort
think they were $220 each?
Discussion Starter · #8 · (Edited)
Hi again,
I feel more confused now after reading that post. Math and numbers added with internet forum short speak just will spin me upside down. But after a little deducing I may be on the right track. So here goes, please let me know if it is correct or not!
From what I understood from that post is that the Chevy Volt battery is 288v.
From what was stated above and in the post the battery pack is 7 batteries @ 2kwh each plus 2 batteries @ 1kwh.
The math of that is 16kwh.
16kwh is 16,000 volts.
:confused:
Ok so realistically the 288v number is more of what I should be working off of. If my system is 144 volt max then I could assume that I would need half of the Chevy Volt batteries? I could do 4 @ 2kwh?
Update: @McRat says
Roughly 18 x 12 x 11 high for 2 x 2kWh in a block.
There are 4 blocks:
2kWh + 1kWh (72v)
2kWh + 2kWh (96v)
2kWh + 2kWh (96v)
2kWh + 2kWh + 1kWh (120v)
so I could do the 2+2+1 configuration.
Would be nice to be able to put the drivers seat back further so I could actually drive it.
Hi again,
:confused:
Update: @McRat says
There are 4 blocks:
2kWh + 1kWh (72v)
2kWh + 2kWh (96v)
2kWh + 2kWh (96v)
OK
Lets start
FIRST there are Volts and Amps - Volts x Amps = Power - Watts
Then there is capacity - measured in Amp Hours - one amp for one hour
16 kWh - is capacity and means that you can DRAW 16 kW for one hour - or 160 Kw for six minutes
The Volt battery has 288 CELLS
These are arranged in threes
So it has 96 Groups of three cells - the three cells are in PARALLEL
The Modules are
12 Series x 3 Parallel - 2 kWh - Seven of these
6 Series x 3 Parallel - 1 kWh - two of these
The individual CELLS are 3.5 volt empty and 4.1 volt full
So a 2 kWh module goes from 42 volts to 49.2 volts
The whole pack of Seven 2 kWh and two 1 kWh goes from 336 volts empty to 393 volts full
The whole pack is 16 kWh and nominally 350 volts
Which gives 45 Amp Hours - for the three cells in parallel - so each one is 15 Amp Hours - 15Ah
You can divide the pack up in all manner of different ways - it's generally best to use the highest voltage that you can
You have an Open Revolt - good controllers - I would run two "strings" each one would be three of the 2 kWh modules
The voltage would be 126 volts empty and 147 volts full
Which would give 45 x 2 = 90 Ah
That sound like less than your old 114 Ah batteries but with Lead acid you only get the 114 Ah at a very low discharge rate - far too low to be useful in an EV - in practice you would be lucky to get 60 Ah out of the 114 Ah batteries - so 90 Ah is about 50% more
That leaves one 2 kWh module and two 1 kWh modules left over - you could either get hold of another 2 kWh module to make up another string or use them for another project
You do appear to be confused. The first-generation Chevrolet Volt battery pack contains 288 cells; the full pack voltage is not 288 volts.
This GM document describes the two generations of Volt battery pack:
VOLT_BATTERY.pdf
Yes, the nominal energy storage capacity of the first-generation Volt battery is 16 kWh, but those nine chunks are usually called "modules", not "batteries".
:confused:
You certainly are confused! "kWh" is thousands of watt-hours, and watt-hours are not volts. Do you really not understand the difference between energy and voltage? Some basic electrical education may be in order... or maybe that was just a typo?
Update: @McRat says
There are 4 blocks:
2kWh + 1kWh (72v)
2kWh + 2kWh (96v)
2kWh + 2kWh (96v)
First, the full Volt battery pack voltage is 360 V, not 288 V. So half a Volt pack would be 180 V (nominal), not 144 V. I don't know if your controller can handle that.
The discussion of the combinations, though, is reasonable. Yes, you can string together fewer than the full set of modules to get a lower voltage and lower energy capacity, with the same peak current capability.
The 2kWh + 2kWh + 1kWh "block" is a set of modules which are bolted together in the Volt pack, so they are relatively easy to handle as one chunk, and there is work required to split that block into the three modules. If that combination works for you, a single block would be your car's entire battery pack... but it would have only 5 kWh of capacity, which isn't much.
A small correction: normally module voltages are the nominal voltage (sort of an average between fully charged and fully discharged), and for the first-generation Volt modules that's 45 V (~2 kWh) and 22.5 V (~1 kWh).
Discussion Starter · #11 ·
That was just a google search result site answer to my conversion. It seemed wrong and didn't make sense so i could have not included that part since i threw it out into the figuring.
And yes I do know basic electricity and confident with basic skills, just not the math :D . Thanks for the yes or no answers, that helped!
With 5kWh of capacity determine the ability to climb a 22%+ grade over 1/3-1/2 mile? (The reason the current cheap walmart lead acid batteries are toast)
@Duncan Thank you that helped answer some o my questions!
Thank you all for your time!
1 - 11 of 11 Posts
