Hello I am able to fix your micro veto please contact me on WhatsApp +48504954025
The car is still driveable but on a hill it is almost impossible o start.also provide the inverter model
The battery is fine and nothing is turned off. The only problem there is not enoughe torque. Once the motor is turning everything is fine. Just from zero to the first turn there is a problem. Once I need more torque from the motor/inverter is interrupting the power.I understand that you are going and turn off the main contactor ??? Please check which contactor switches off first or second first - this is the one in a small aluminum box next to the lamp and the second - this is the one in the inverter
Yes thats rightI understand that nothing turns off, only the engine has no power ???
No message shown because its just a limit and no failureshows a message on the display?
I know because it is dos based. I need some tips which win xp version works and which serial interface...shows a message on the display?
No message is shown.shows a message on the display?
Sounds like a defect battery cell,Or bms fault. But you have already tested them-The car is still driveable but on a hill it is almost impossible o start.
