Help! Zilla problems
1673 6
I do not want to send My Zilla 1k-LV back to the shop. I am hoping
that the EV-Brain trust can help me.
Short story. I got my Zilla. Hooked it up and it ran. Drove my
car for 2 miles. Parked it, turned everything off. Started chargers
and went to bed. Next day she won't run. Hairball will not talk to
the power unit. Also there is a 56 volt short too ground/body of the
car. I figured that it was the motor. Got the motor back from the
shop, with a clean bill of health and a bill. Hooked it to the Zilla
(1132 error) hairball will not talk to the power unit. I also have a
56 volt short to ground/body of car. If I disconnect Zilla (M+) from
motor, short goes away. If I move the volt meter one battery farther
from the Zilla, the short drops 6 volts. Is this something with the
motor or Zilla? Is it something I can test for.
My feeling is that this is just something that happens. Some
component in the power unit, stressed itself and failed. I just don't
want to be wrong.
TIA
R. M. Milliron
[email protected]
1981 Jet Electrica
http://www.austinev.org/evalbum/702
This machine has been garaged for 17 years.
I am upgrading it and getting it running. Tabitha,
my daughter, named it, "Pikachu". It's yellow and black,
electric and contains Japanese parts, so I went with it.
1 - 7 of 7 Posts
Discussion Starter · #2 ·
Hey Matt
Being you just had the motor worked on I doubt there
is a short to frame there. I've seen where assuming
gets you so taking a test of the motor is easy. Use a
multi-meter and see whether you have continuity
between any terminal from the housing.
While you're there testing it, do a 12 volt bench test
to see that the motor does in fact work (if you didn't
already after getting it back from the shop) again
just to make sure so you can cross this segment off
the list so to speak.
Being that the motor's been worked on and the problem
remains it adds to it not being the issue but like I
said if you want to cross it off you'll at least know.
Bummer to hear you're having troubles, keep the chin
up and trace it till you find the little bugger 8^)
Sorry I can't help more on the controller but Otmar
wouldn't let me see the insides of one 8^o, LMAO!
(kind of a private / public joke) 8^P No diff really
as I couldn't tell ya what I saw if I saw it, being
I'm the motor guy 8^)
Hope this helps a little ><
Best of luck
Jim Husted
Hi-Torque Electric
> shop. I am hoping
> ran. Drove my
> Started chargers
> will not talk to
> ground/body of the
> motor back from the
> unit. I also have a
> one battery farther
> something with the
> happens. Some
> want to be wrong.
> TIA
> R. M. Milliron
> [email protected]
> 1981 Jet Electrica
> black,
> it.
Park yourself in front of a world of choices in alternative vehicles. Visit the Yahoo! Auto Green Center.
http://autos.yahoo.com/green_center/
Hello Matt,
If you connect directly to a main contactor, that may have a large inductive
kick when the contactor is turn off. This is what my did and the hairball
and it took out the driver circuit for the contactor.
It is recommended by Otmar of Café of Electric, to install a snubber across
the main contactor coil. This diode is a Zener Overvoltage Transient
Bidirectional type. I use a NTE-4933 or equal type.
The inductive kick in some contactors is too large for the hairball and can
damage it.
I use both the NTE-4933 suppression on the contactor coil, plus I have the
hairball contactor circuit, drive a small 12 volt relay that only draws
about .1 amp and have this relay turn on the main contactor. I took off
directly off the ignition key circuit, because my large contactor draws
about 5 amps.
The 56 volt is not a short in the way you think. When the batteries are
charge, they vent and these causes a conductive path from any one of the
battery terminals to the chassis ground of the EV. After charging, you may
read a voltage from one of battery terminals to ground. You can even read a
conductive voltage from the post to the plastic case of the battery. This
is normal for a venting battery.
Now when you have this conductive path from you battery pack to vehicle
ground, the other path may be through your motor to ground. This current
path is from the negative of the battery to the negative of the Zilla
controller directly tie to the negative M- to the motor.
When a DC motor is ran for a period of time, there is brush dust that forms
a conductive path from the brushes, down the face of the commentator and to
the motor shaft and frame of the motor which also makes contact to the
vehicle frame.
This is your conductive path, one battery feed line from the battery to
frame and the other battery feed line that goes directly to the Zilla, to
the motor and then to ground. This is your current circuit.
To current path is induce by a higher voltage when you batteries are
charging. If this conductive path is not broken, more brush dust will
increase this current path, and the voltage could get up to the full battery
voltage.
When charging your batteries, it is best to disconnect both the positive and
negative battery leads to your controller. I use two more contactors, which
is the same size of the main contactor, which disconnects the batteries from
the controller and motor when the ignition key is off. I use another small
12 volt relay control by the ignition circuit to control these two battery
contactors, which normally are call safety contactors.
Safety contactors are also control by a on dash or on console kill switch,
just in case the main contactor or controller fails.
Also, if you have a on board battery charger, it is best to have a two pole
50 to 75 amp contactor which is used to connected the battery charger to the
batteries. If I leave my PFC-50 battery charger connected to the batteries
at all time, the battery circuit will arc every time the battery circuit is
disconnected some where in the circuit.
Always disconnect the battery charger from the batteries, which should be
some distance from the batteries them selfs, if you disconnect a link off a
battery. With my battery charger connected and even not plug in to the AC,
the links will arc when I disconnected. This could blow up your batteries
if you have battery fumes present.
A 2 pole battery contactor on the DC side of the battery charger will
prevent this arcing, plus cut out another conductive ground path, if you
battery charger is grounded to the vehicle.
I install my battery charger inside a epoxy coated fiberglass enclosure, the
main battery pack in a epoxy coated fiberglass enclosure, plus two
contactors to isolated from the controller and another set of contactors to
isolated from the battery charger while the EV is running.
I now have only .1 to .7 volt conductive current path to ground now.
When installing a new DC motor that has brushes, I take a ohm reading of the
motor terminals, (disconnected from the controller), to give me a reference
of the conduction to ground. When motor is new it will read over 20 meg
ohms from any one of the battery terminals to the motor frame. As time goes
on, it is normal for this to get to 30 to 50 K ohms which is cause by the
brush dust and its time to clean the motor.
When I did maintenance on the motor, which means breaking it down, clean it,
replacing the brushes, megger the motor circuits, and had the commentator
turn and all the windings re-enamel and a weak spot in one of the field
windings repair, I also had the motor shop apply insulating enamel on the
face of the commentator down to the motor shaft and on the motor shaft up to
the bearing surfaces. Also I had them spray a insulating enamel you can
also get in a spray can from the motor shop, which I use to spray all the
inside metal surfaces of the motor after the field coils are install. The
field coils shoes must have a metal to metal contact with the motor housing.
It is best to call or Email Otmar on your hairball. I had to send my back
to him, he replace the driver circuit for the main contactor and got it back
in about a week which he included some Zener Overvoltage Diodes to be
install across the contactor coils. The controller has been working good for
about 5 years now.
Roland
----- Original Message -----
To: <[email protected]>
Sent: Thursday, July 26, 2007 9:42 PM
Subject: Help! Zilla problems
> want to be wrong.
> TIA
> R. M. Milliron
> [email protected]
> 1981 Jet Electrica
On 26 Jul 2007 at 23:56, Roland Wiench wrote:
> When a DC motor is [run] for a period of time, there is brush dust that forms a
> conductive path from the brushes, down the face of the [commutator] and to the
> motor shaft and frame of the motor, which also makes contact to the vehicle
> frame.
Not to rekindle the AC-DC wars, but this is one advantage of an induction
motor AC drive - no brushes, no brush dust. ;-)
EV List Administrator
Want to unsubscribe, stop the EV list mail while you're on vacation,
or switch to digest mode? See how: http://www.evdl.org/help/
Note: mail sent to "evpost" or "etpost" addresses will not reach me.
To send a private message, please obtain my email address from
the webpage http://www.evdl.org/help/ .
Flame On ;-P
A year and a month and that hasn't happened to me yet. I'm not saying it won't. But I wouldn't worry a new person about it being that big of a problem though. The capital cost difference was worth having to take the time once a year to take an air hose the to motor.
Mike
Date: Friday, July 27, 2007 9:09 am
Subject: Re: Help! Zilla problems
To: [email protected]
> dust that forms a
> the vehicle
> > frame.
> induction
Hey Jim,
I gotta say motors out of your shop look a whole lot
nicer than what the other guy did for Matt's MTC. Not
to say they didn't do a decent job, but you can tell
it is not the master's work.
And Matt,
About that 56 volt ground. Is that from battery pack
positive to frame? Try taking a 1K or 2.2K Ohm
resistor and wiring it from pos to frame and measure
the drop across the resistor. Does the voltage go
down from 56? Use I = V / R to calculate the amps.
Milliamps, hopefully. If you're below 10 milliamps,
it is probably leakage paths from the batteries,
either tracking from terminals outside the cases or
even thru the plastic cases.
Jeff
--- Jim Husted <[email protected]> wrote:
> Hey Matt
> a
> test
> didn't
> problem
> know.
> really
> Best of luck
> Jim Husted
> Hi-Torque Electric
> > shop. I am hoping
> it
> > ran. Drove my
> off.
> > Started chargers
> Hairball
> > will not talk to
> > ground/body of the
> > motor back from the
> > unit. I also have a
> > one battery farther
> > something with the
> > happens. Some
> > want to be wrong.
> > TIA
> > R. M. Milliron
> > [email protected]
> > 1981 Jet Electrica
> > black,
> with
> > it.
> Center.
Take the Internet to Go: Yahoo!Go puts the Internet in your pocket: mail, news, photos & more.
http://mobile.yahoo.com/go?refer=1GNXIC
Discussion Starter · #7 ·
--- Jeff Major <[email protected]> wrote:
> Hey Jim,
> Not
Hey Jeff
First off, thanks for noticing 8^) I hadn't seen that
Matt had thrown up a pic so after your post I ran on
over to take a look @@
Now my momma told me if I didn't have anything nice to
say then not to say anything at all 8^o So I'll just
say that at least it looks better than it did 8^P
Now beauty is only skin deep but I've heard ugly can
run all the way to the guts, LMAO, and being I see
they painted the fan I'm betting they hosed that
armature down as well, which is a shame. Although I
do coat areas with Glyptal I make sure to leave the
natural insulation clear dipped so you can see if it's
overheating and begins to darken the insulation, where
as if coated in red paint or glyptal it's hidden from
view. Just a heads up for other to not have your
armature coated solid.
In fact my first boss was a hard core Christian and
used to use the phrase that Glyptal was like the blood
of Christ, it hides sin!
Personally, if this was my motor, I'd have beaten that
guy with the same 14' ugly stick he used to build that
motor with 8^o
Sorry Mom I'll go wash my mouth out with soap for
talking trash 8^)
BTW IMO Pikachu's motor should have been Yellow or
black!
Got to run and go chew some soap now 8^(
Cya
Jim Husted
Hi-Torque Electric
____________________________________________________________________________________Ready for the edge of your seat?
Check out tonight's top picks on Yahoo! TV.
http://tv.yahoo.com/
1 - 7 of 7 Posts
